SailNet Community - View Single Post - Furling Line Hardware -- A New Option
  #13 (permalink)
Old 11-14-2008
artbyjody's Avatar
artbyjody artbyjody is offline
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
The most important aspect of furler systems is how well you can pull the sail under load. Your stanchion blocks - how they are configured are the most important aspect of the design.
It has nothing to do with "you welt your legs" aspect. If you are welting then you are not sailing properly!
Lotsa of comments on using winches etc, all wrong using winches on furling lines period!!!!...Never!!
simple solution...
run the fairleads outside the stanchions for best mechanical advantage...It is where they should be actually. You get a better angle for starters...
Secondly you keep the deck clear.
The last stanchion block should be 45 degrees to point of incident. IE: 45 degrees to where you pull. It will stick out a hair but provide you the man handling leverage to pull in the genny / jib without using the winch. NEVER EVER use a winch to pull out the furler line... trust me - many $$$$
It either works or it does not and when it does not, it is human error not a result of the furler..Usually wrapped halyards at top of mast of mast or no slack in the tacking leads..
-- Jody
S/V "
1983, Barberis Show 38! or
