SailNet Community - View Single Post - two person monohull, how big?
post #9 of Old 11-16-2008
sailingdog
YD-
Idiens' advice on the boat being sailable by either you or your wife singlehanded is one I've given you before. Anything larger than about 40-45' is going to be very difficult for you or your wife to singlehand. Electric winches don't help flake and stow sails, as I've said before.
Larger boats have higher on-going costs... smaller boats are far more economical to cruise on long-term... so a lot depends on what your plans are, how much "gear" you need and so one. If you and your wife require creature comforts of a land-based life, you really may want to re-consider what you're doing.
Living aboard and cruising is often uncomfortable and requires that you often do without some of the creature comforts found in a land-based life. While this is less the case today than it was even ten years ago, getting a boat large enough to have the comforts of a land-based life is very expensive.
sailingdog is offline
