Why would anyone design a solar panel that way. It doesn't make sense and would increase the cost of the panels incredibly. Solar panels are generally used to charge batteries. As such, they need to output relatively low voltage DC... trying to convert the low-voltage DC output to a high voltage AC output would require fairly sophisticated and inefficient hardware—specifically an inverter. Then to use the electricity on the boat, say to charge the batteries, you'd have to convert it back to DC... incurring even further losses.
The most cost efficient way to keep the batteries charged when dry docked is to take them home and put them on a three-way smart charger about once every two weeks.
