Originally Posted by Capnblu
You are correct Gramps, unless you then apply the MAX-PROP to the equation, lowering the rpm's for the same thrust.
Yes, you can do this, but it won't change much in the way of fuel use. Industrial diesels usually are most efficient near their rated speed. Here's the data for a Cat engine:
The bottom graph is the Brake Specific Fuel Consumption in pounds per horsepower-hour. For a given horsepower load, the engine burns more pounds of fuel when it's run slower.
Tim
