SailNet Community - View Single Post - Engine dies
Thread: Engine dies
Old 11-20-2008
Kiskadee Kiskadee is offline
Wharfinger
Kiskadee is on a distinguished road
I agree - Fuel Problem
I'm sure you're correct to believe it is a fuel problem. Heat or RPM related problems with any part of the ignition would either cause a lack of power at higher RPM or not allow it to restart so quickly.
A big question is how an engine sounds when it stalls. Did it stall instantly or did it stumble a bit while stalling? If it ran out of fuel it may taken between half a second and three seconds to stall. If it's electrical or electronic it may have stalled instantly.
Your problem sounds like the carb isn't getting enough fuel in the float bowls. When you ask for increased RPM it uses up the fuel from the bowl faster than it can refill. This could be due to a few things.
-A restriction in the fuel line: Check for kinks in the rubber line or dirt in the tank pickup tube. You should be able to blow fuel back into the tank without excessive resistance. (But your problem persisted with the aux tank.)
-Weak fuel pump: Although new, the pump may not be working correctly. The engine should run from the aux tank with the fuel pump bypassed, if the tank is two or three feet higher than the carb.
-Wrong fuel pump: The A4 only needs about 2 psi fuel pressure. There are two electronic pumps available at Moyer Marine. If the engine is below the tank use the 2-3 psi model and if the tank is well below the engine use the 3-4 psi model. Some Catalina's need 3-4 PSI. Insufficient pressure would not allow it to hold high revs.
-Incorrectly adjusted carb floats: If the floats are set too low they will close the needle valve early with the float bowl only partially full. This is easy to set. Split the carb in half (4 screws) and turn it upside down. The floats should sit parallel to the carb body.
-Blockage inside the carb: There is a small chamber between the carb's fuel hose fitting and the top of the needle valve seat. If dirty it may restrict the flow of fuel. Too much teflon tape on a fitting may be stuck on top of the float valve seat.
-Wrong type of hose: Make sure every inch of rubber hose is rated for gasoline and is CG approved. Some rubber breaks down in gasoline and swells up, restricting flow. I've seen this screw up a motorcycle when the owner used vacuum hose as fuel line.
This past summer my fuel pump died and I ran for several hours with a jerry can in the cockpit and just gravity feed to the engine. Good luck with your A4, which is still one of the best little engines made.
