The 4-108 is a good old heavy block, and I'm sure it would handle turbo or supercharging ( they more or less have the same effect). However it will need changes to the injector and injector pump settings. I suspect that the longetivity of teh engines would be effected. But It would work, just for how long. I suspect a bit of research you will find that that block has been turbocharged by somebody maybe even perkins. IT as been used all over the place.
