Thread: Any Gearhead's?
  #28 (permalink)
Old 11-21-2008
Gramp34 Gramp34 is offline
Gramp34 is on a distinguished road
Originally Posted by Omatako View Post
An intercooler (between the turbo and the inlet manifold) is what you're talking about. Aftercoolers are actually quite rare.
Here's more of that Cat datasheet:
I guess nobody told Caterpillar (or Cummins or Detroit Diesel) that aftercoolers are quite rare.
Wrong. The air being blown out of the exhaust spins one end of a turbine, the other end of the turbine compresses the air into the manifold. It has nothing to do with heat. Heat is the biggest enemy of engine efficiency which is why there are things like pre-coolers, intercoolers and aftercoolers.
No. A turbocharger consists of a turbine and a compressor connected by a shaft. The intake air comes in contact with _only_ the compressor and doesn't get near the turbine. It's the compression of the intake air that causes it to be heated, not any contact with the exhaust. By cooling the heated intake air it becomes more dense, allowing more oxygen to be crammed into the fixed displacement of the cylinder, which allows more fuel to be burned.
The turbine section is powered by the heat energy in the exhaust, rather than taking energy from the crankshaft. (In fact, the Detroit Diesel DD15 uses an extra turbine stage in the exhaust geared to the engine to develop an extra 50 horsepower and improve fuel efficiency by 5%. This is a case where engine efficiency is improved through turbocompounding.)
Sorry fellows, that last piece leaves me speechless. No I can't leave it there. The energy used to turn a supercharger is a very small fraction of the power that results from the charging of the engine. To say that the result will be the same or less efficient, is nothing short of daft.
Gramp has obviously never heard of drag racing. Nufsed.
You're trolling here, right?
From Wikipedia: "A top fuel dragster can consume 6 U.S. gallons (23 L) of nitromethane for a quarter-mile (400 m) run in about 4.5 seconds, which comes out to 24 U.S. gallons per mile (5600 L per 100 km). "
That's 0.042 mpg. (About 200 times worse than a Hummer.) You call that efficient?
Efficiency is energy out divided by energy in. The OP's sailboat requires the same energy out, but if you're driving a supercharger that's going to put more load on the engine, it will cause the engine to burn more fuel. Energy in goes up, efficiency goes down.
More air in the cylinder means that more fuel could be injected and burned, and the engine could produce more power. If you're not putting an extra load on the engine, the injection pump won't inject extra fuel, and that extra air is just along for the ride. It gets pumped into the engine, and pumped out the exhaust, taking energy to do so, but providing no benefit.
The OP's idea is to supercharge to produce his necessary power at lower RPM and repitching his prop to absorb that power. It'll make a cool sound, but I don't see much in the way of saving fuel.
Tim
