Old 11-22-2008
heinzir's Avatar
heinzir heinzir is offline
Junior Senior
heinzir is on a distinguished road
Originally Posted by AllThumbs View Post
That is awesome. I have a lot to do on mine and the ideas from these photos is great. Let me ask you, the strapping that the cedar(?) is fastened to, it is epoxied onto the hull?
The strips behind the cedar are cut from 1/2" pressure treated plywood. I had to cut kerfs in them to allow them to conform to the curvature of the hull. I bought the cedar strips at Menard's. They are 5/16" thick tongue and groove strips sold for wainscoting.
Conventional wisdom says to epoxy the furring strips to the hull. I was working on the boat outside in my driveway in early winter and the temperature was way too cold for epoxy to set up. I used Gorilla Glue instead. It has a broader range of temperatures it can be used with. I left a worklight on in the boat that generated enough heat to keep everything above freezing.
I did this last winter, and so far the Gorilla Glue has held up well. Here in Minnesota we get temperature extremes from -30 in the winter to +95 in the summer. Also, this is a very lightly built boat so it probably flexes more than a more substantial craft (although I have never actually noticed any flexing.) Neither the flexing nor the temperature swings have broken the Gorilla Glue bond.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
http://community.webshots.com/slideshow/230613770IXBurv
