Old 11-23-2008
sailingdog sailingdog is offline
You'll probably want to consult with a professional rigger or marine architect, but having the spreader tips out of a straight line between the chainplate and the mast tangs strikes me as being a bad idea. The tension on the spreader isn't just in compression then, it is also torsional, and most spreaders aren't going to tolerate that well. The shroud, ideally, should be a straight line when viewed from the outboard side looking in.
Is the mast original to the boat? If not, you might want to find out what the original mast and spreaders setup for your boat, as originally designed, looked like.
A good book on rigging is Brion Toss's The Complete Riggers Apprentice.
