SailNet Community - View Single Post - An alternative way to attach a harness
post #7 of Old 11-26-2008
sailingdog
Erps-
While this might work well for you, it would cause you some issues if you have people crewing for you that don't have the same type of harness modification you do. That means you'd be having to supply the harnesses to go with the tethers on your boat, and train the crew how to use them properly.
If it is the rattling that is what bothers you, why don't you just take a short 2-3" section of the outer braid off a piece of 1/2" dacron double braid and use it to cover the majority of the metal on the hooks. That would stop the rattling.
Originally Posted by erps View Post
I've been thinking about an alternative way to attach ourselves to the boat. I'm familiar with the standard way, a tether with a quick release hook attached to the D-rings of the harness, the other hook attached to an anchor point or jackline. I don't like the idea of the lower safety hook rattling around at the anchor point or rattling up and down the deck on the jackline.
I've been thinking of permanently attaching the quick release hook to one of the harness D-rings with a short length of line through the eye, leaving the quick release part hanging free. I would make up another length of line tied to the anchor point or jackline with a loop at the bitter end. When its time to clip in, I would thread the quick release hook through the other D-Ring, then clip into the loop at the end of the tether line. It would do away with the second hook rattling around the the deck and it would be a fraction of the cost of store bought tethers. Just thought I would throw it out there to see if someone has already tried something like this and discovered it just doesn't work.
sailingdog is offline
