lowest drag for fixed 3 blade?
How about a used two blade fixed prop? I suspect that there are some out there, since it is a common refit to change to a folding two blade prop.
Otherwise, I think it should be locked. You might find which position is best by marking the shaft with two blades up and two blades down then testing.
