Old 11-30-2008
sailingdog sailingdog is offline
Also, it should require a minimal amount of equipment and materials. Welding is fine if you have a shop, but not so good if you're based on a boat. Diesel engine repair might be a good choice, since you'd probably be carrying most of the tools required anyways, and they're not going to take up a lot of extra space as a result. However, materials and repair parts are a problem for a traveling diesel maintenance person.
Writing is an excellent profession for a cruising sailor... but requires skills that most do not have, and is a hard way to make a living for most.
A lot of the IT professions can be done with relatively minimal equipment...since many would require just a laptop and a decent internet connection. This works when you're in ports with decent internet access, but isn't as viable if you're anchored out or on passage.
Originally Posted by xort View Post
If there is good, easy money to be had, a lot of people would be doing it. And if there is a lot of money, the local gov't will be looking for you for working without a permit.
So you will need a task that few people can do and that can easily fly under the radar.
