Old 11-30-2008
SEMIJim SEMIJim is offline
Nautical Newbie
SEMIJim will become famous soon enoughSEMIJim will become famous soon enough
Originally Posted by PotterSquatter View Post
However, with the large Genoa on, the Jib Sheets are led outside the shrouds to the Genoa track blocks on the outside of the cockpit, and the lines seem to hang up and rub heavily on the shrouds and shroud attachment gear until I get the boat turned and get the Genoa full of air and away from the boat.
So, what am I doing wrong? Or is this just "the way it is"?
Wellll... that depends
Depending on a number of factors: There is usually a "sweet spot," in coming about, where you can release the one jib sheet and haul in the other, have nothing foul on the way across, and actually get the sheet trimmed to just where you need it, or darn close, without the winch handle. But if you're too early, too late, the air's too light, etc.,: Yeah: It'll hang on things coming across.
Btw: We have long plastic shroud covers on our forward lower shrouds, to reduce chafing on the sail. I just tried to find them, but could not. Odd, I would've thought them common as dirt.
Jim
s/v Abracadabra
1976 Pearson P30
