Originally Posted by Gary M
In all but heavy weather hold your old sheet until the headsail fills as you go through the tack and then release and pull it in smartly on the new tack. That should help your situtation out.
Good Luck
Gary
Gary, thank you for the tip! I will admit that I've only had the opportunity to use the Genoa in fairly light airs. If the winds been up at all, I've used the working Jib as I'm still a bit chicken as a newbie sailing single handed. It's possible that it will only be an issue in these cases and in a better wind it may not be an issue.
I'll try these things at next opportunity.
Take care,
Don
