Old 11-30-2008
cardiacpaul's Avatar
cardiacpaul cardiacpaul is offline
MarineSurveyor
cardiacpaul is a jewel in the roughcardiacpaul is a jewel in the roughcardiacpaul is a jewel in the rough
first, I'd say whack the side of the bowl (between gently and semi-gently... those are technical terms) with the handle end of a decent sized screwdriver. That will jog loose most gunk that might be causing your sticky float.
1) Since I have done no maintenance to the carburator since owning this boat should I just bite the bullet and take the whole mess off and give it a good cleaning (servicing where needed) even if I've never done this before?
yup, know what carb you've got before you call moyer, I think they used three different ones OR take it off and hike it in to your local NAPA store and ask for a rebuild kit.
You'll get all (two or 3) gaskets, a new idle needle and seat, and a new float (or float valve)
2) Should I try the method of removing the main passage plug and running some fuel through first? This method does not require the removal of the carb unit.
I think you're going to end up with the carb in your car driving it to town anyway, so don't bother. The access is a real pain in the patootie, and I sure wouldn't wanna drop anything.
3) Is it likely that by using the carb cleaner through the flame arrestor/intake that I inadvertently got junk into the float valve OR is it just as likely that this would happen eventually?
See, two different paths of entry... the carb cleaner went in thru the air intake. That has NOTHING to do with the float valve. Think of the bowl float as you would your toilet tank filler. The gas gets "vacuumed" up by the venturi in the carb.
When the gas gets "low" in the bowl, the float opens and lets some in. This happens in dribbles, not gushes. More likely, a speck of dirt in the gas got stuck in the valve.
4) Is using carb cleaner a good idea in the first when the engine is running?
Usually the spark arrester is chock full of gunk, grime and bug guts. Using it didn't hurt all that much unless some of the above got stuck in the venturi of the carb. Thats unlikely, it would have a hard time running if it did.
That being said, next time, remove the spark arrester, clean that, and spray away into the intake while its running.
5) Am I missing something?
are you sure its coming from the carb? check the fuel pump, there is a bowl on that too. (no float)
"sooty plugs"
Because you use the engine for a short time, it doesn't get hot enough to burn carbon off... take her for a long legged motor cruise (an hour or so once a month, she'll love you for it.)
Or, use one heat range hotter plug
On some carbs there were two "adjustments", others only one. If you have the "only one" type, you've futzed with the idle mixture, either leaning it out (by turning it "in") our richened up the mix (may also be a cause of the sooty plugs, by turning it "out") Be careful, too rich is far better than too lean.
If my brain cells are still working, start by screwing it all the way in (fingers only, these bits are copper, don't wanna leave marks in 'em), then try a half a turn out. start motor, keep turning (1/4 to half, max 2 turns) until the motor runs rough, then screw it back in a little till it levels out. then, leave it alone.
If you have the 'two screw" type, repeat the process with the engine under load.
Please be careful of spinning parts when the engine is running. I have found that there is less of a chance of my shirt getting tore off and me being wound up into something that doesn't care if i have flesh on my bones, if she's already nekkid.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Sponsored Ad
