SailNet Community - View Single Post - Battery life? Winter storage?
post #2 of Old 11-30-2008
sailingdog
If the batteries are fully-charged, then they should probably do fine. The question is whether they're AGM, GEL or "maintenance free" wet-cell batteries. If they're wet-cell batteries, then they will probably need to be re-charged occasionally while the boat is on the hard.
Detaching the negative means that there won't be anything using the battery, discharging it. However, all rechargeable batteries self-discharge to some degree, with wet-cell batteries having the highest self-discharge rate of the three commonly used lead-acid types.
As for how long the batteries will last, really depends on how well they're treated. Most are killed by neglect far sooner than they would ever die.
sailingdog is offline
