Just curious, why would you want a diesel to replace a perfectly good Atomic A4?? It is a very expensive upgrade that will not be recouped if you sell the boat. An Atomic A4 is a simple and relatively bullet-proof engine.
As for the swing keel/centerboard being sealed up...that's a minus in my book. The centerboard helps with the boat pointing in deeper waters and helps prevent leeway. Without it, you've got a boat that is shoal draft, but doesn't point very high or well, and tends to sideslip far more than she should.
Would highly recommend you read the
Boat Inspection Trip Tips thread I posted a while back. It should help you figure out if this boat is worth proceeding further with.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
