Window replacement
6K views 10 replies 6 participants last post by  resdog
#1 ·
most of the windows on my catalina leak. i was planning on removing, re-gasketing and reinstalling this winter. should i replace the glass with acrylic or would it be better to apply some window tint to the interior of the glass. i like the darker windows to give a bit more privacy at the dock. i'm worried the exterior side of the acrylic would get scratched after a while from cleaning the exterior of the boat. i usually use brush on a pole to scrub down the boat after a sail.
#2 ·
If the brush is clean of grit and has soft bristles, it shouldn't scratch the acrylic noticeably.
However, I would recommend using a polycarbonate, like Lexan or Makrolon, with an anti-scratch/UV-resistant coating instead of glass or acrylic, unless you can get fairly heavy laminated tempered glass cut to the right shape for the ports on your boat. Chances are likely that the "glass" isn't actually glass, but acrylic of some sort. Polycarbonate is far stronger and breakage resistant than acrylic.
#3 ·
I am also doing my windows. I have learned through research that Polycarbonate (lexan) is much, much stronger than acrylic (plexiglass), however it is softer so it sratches more easily. It's worth the tradeoff tho as acrylic is much too brittle and will often crack when being drilled and/or installed. lexan has been used to build see-thru snow plow blades and is almost indestructable. You can fold it 90 degrees and it wont crack.
Eric
#4 ·
sd,
actually the glass is glass. its original to the boat from 1978. the glass is in good shape so i can re-use it. its the surrounding gasket which needs replacement.
allthumbs, thats what i was worried about with the lexan/acrylic. i installed a new lewmar port this summer with an acrylic lens. just from general cleaning of the boat it is getting minor scratches on it.
#6 ·
Hmm... that's very unusual.... but if it is in good shape...re-use it by all means. Automotive tint film is probably your best choice for darkening it. :)
#7 ·
I would say forget the old stick on window tint. There is a new technology that has surpassed the old window tinting ways and it is spray on window tinting.
You do it yourself and should be able to make it as light or as dark as you want it. I have seen some things that were sprayed with it and they looked excellent.
I would be worried that the sticker tint would begin to peel in a marine enviroment. I am planning on using this stuff on my South Coast 22 project boat some time soon.
You can get this one at summitracing.com and search tint at the top in the search box. There are other spray tints out there too.
#10 ·
Since you've got glass in good shape I'd most certainly reuse it.. all the other replacement options will eventually go opaque with time. even Lexan, and while strong it's remarkably easy to scratch.
We've had success replacing the gasket seal with aluminum-framed ports with Dow Corning 795 sealant. Save some small pieces of the orignal rubber to center the glass in the frame. Mask off the glass and the frames to ease cleanup after it's all assembled.
Good luck.. it's pretty nice to eliminate window leaks!
#11 ·
I replaced my fixed sidelights on a Beneteau First24 with tinted acrylic and used the 3M VHB 2-sided foam tape (Very High Bond). Once I got the window positioned on the boat properly I used a laminate roller to make sure the bond was good between the acrylic and the boat. The windows are not going anywhere and I haven't seen a drop of water inside the boat. What it's going to do when the rail is under water next summer is another question. We've got a few months to see.
