SailNet Community - View Single Post - How attach reefing lines
  #11 (permalink)
Old 12-02-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
Originally Posted by Bene505 View Post
This is for our Beneteau 50, not loose footed. We had it reefed last month and tied a bowline directly to the eye in the sail (kringle?).
Definitely don't do it this way!! But you already seem to recognize this isn't the right approach.
I'll only add to the good advice above that it is preferable to have the termination point for the reefing line (where it secures to the boom after passing through the cringle) somewhat aft of the cringle itself. This helps to get good outhaul tension on the reefed sail.
If you reef the sail with insufficient "outhaul" tension (provided by the reefing line), you can end up with too much draft in the sail and it may not depower as you'd expect from taking a reef.
