SailNet Community - View Single Post - Can you winterize an engine without running it first?
Old 12-04-2008
DrB DrB is offline
DrB is on a distinguished road
Winterizing the motor
Two things need to happen:
Oil Change and Anti-Freeze the Raw Water side of your motor.
Oil Change works best if you can run the motor for 5 minutes or so and let it warm up. Helps make it flow easier and resuspends the particulates for easier drain/suck out. Change both he oil and filter.
For the Raw water side of the motor, I don't know of any other way to get the anti-freeze into the motor without getting it started. So, if your going to start it to introduce the anti-freeze, do it long enough to get the oil warm and change it.
I see that you live in New England. I hope that your boat has been in the water. If it's been on the hard, we have had a lot of below freezing, so be careful before starting the motor. You may want to put a small heater inside the boat for a few hours to thaw any frozen areas. Hoepfully no damage has occurred.
DrB
