Old 12-04-2008
CrazyRu's Avatar
CrazyRu CrazyRu is offline
CrazyRu is on a distinguished road
What’s the story with winterizing? Remove the hose from seacock, slide big funnel into it, run engine and ooze antifreeze into funnel until antifreeze runs out of rear pipe. On small engine it takes less than а gallon. It is $8 at most. Yes, you have to use right ecologically friendly antifreeze. Yes, it may not replace all water in the engine. Antifreeze is rated for minus 70 degree. It will mix up inside of the engine.
5 minutes later you have your engine ready for next time to go out.
Keep all other systems winterized. Hang solar shower bag with water in it over a sink. Now you have running water for guests. Or just boil a kettle.
Use skiing gear – face masks, gaggles, gloves, bibs, etc… Sail conservatively, use mainsail or genoa only.
I used to sail beach cat in winter. Big boat is too boring; there is nothing to do… It’s colder too, body isn’t working. Still, if weather is nice there is no reason to skip good sailing day
