Servicing older lewmar winch
I have a older model (pre ocean?) Lewmar 40 (and 43) 2-speed winch, and I have a hard time figuring out how to disassemble them.
I can easily take off the circlip and lift off the drum, but I don''t know how to get the center spindle out of the base. It seems that if I can pry off the plastic disk holding down the 2 bearing rings, I should be able to take the spindle out, but I am concerned I might break that disk (and end up needing a hard-to-find spare part).
Does anyone have a Lewmar Service Manual Volume 6 lying around? I understand that manual has the specifics on this particular winch--everything I found on the lewmar website so far is for their newer winches.
Thanks!
