SailNet Community - View Single Post - Bonehead alert: Dropped Outboard in water
  #18 (permalink)
Old 12-05-2008
sailboy21's Avatar
sailboy21 sailboy21 is offline
sailboy21 is on a distinguished road
MLS-
Corrosion-X is great as an anti-corrosive spray, but it is a bit too heavy and sticky to be any good for treating an engine that has been dunked in water.
A lot of corrosion sprays could also leave a coating on internal engine parts preventing proper operation of the reed valves, carb parts, and possibly the rings and seals. You don't want to spray WD-40 directly into the carb or crank case because it will also displace or strip the oil from the bearings.
