I ended up taking apart the carb to drain and clean it and letting the whole rig dry overnight. I was able to get it started on the first pull after putting it all back together. I let it run about 10 minutes at a high throttle setting, but was having trouble keeping it running at idle. I suspect I may need to just adjust some of the carb settings to get it running smoothly again, but it seems to be none the worse for the wear. Time will tell.
Brett
S/V Liberty
1980 Morgan 461
