Owner of a Cal 2-29 1973
I have been restoring a Cal 2-29 I am in the second year of the rebuild but since I am disabled the work is slow. I decided to make some major changes, and have found some problems that are common in Cal 29's.
First, borrow a bore scope or a camera attached to lap top and inspect the steel beam that is under the hump that separates the main salon from the head. You can gain access by going through the head platform where the thru hull is. This beam needs to be in good shape. Also check all of the bulkheads for damage to the plywood. I had to make a new beam, main bulkhead and forward as well. The minor bulkheads that support the rear chain plates were beyond hope. Tiny leaks will destroy any wood, even teak. There is enough room to put in a small holding tank by moving the small water tank aft and upright.
As to the engine you might think of going with an air cooled diesel or using an electric motor (two in tandem) from golf carts. Add a small generator and you have a diesel electric drive. Use golf cart batteries.
