Servicing older lewmar winch
The plastic around the bearings should lift off. Then the bearings lift off. Be careful of the plastic. It''s brittle as hell. Mine are now wired with pieces of plastic left holding the space between the bearings and the winch body. They work fine, but it ain''t pretty. No need to remove the "spindle." If stuff is stuck, WD40 the crap out of it and gingerly take things apart. Clean and dry and use appropriate grease.
