SailNet Community - View Single Post - Trojan verses AGM
post #5 of Old 12-08-2008
sailingdog
Originally Posted by JHJensen View Post
...Steve and SD are correct that you will get more bang for your buck with wet cells if you maintain them. On the other hand if your system is set up properly for the you will get very good service with the AGM batteries and not have to be adding water as you will have to with wet cells.
If you over charge AGMs though, you can dehydrate the electrolyte and destroy the batteries very easily.
sailingdog is offline
