SailNet Community - View Single Post - Stoves - pressurized alcohol or propane, which is better?
post #5 of Old 12-09-2008
sailingdog
L124C-
Don't know where you learned chemistry, but alcohol vapors are generally denser than air.
Also, water in insufficient quantity can spread alcohol fires instead of putting them out... which is one reason alcohol stoves caused some many boat fires... the person would pour water on the fire and the burning alcohol would get washed down into areas of the boat where it wasn't readily visible. By the time they realized their mistake, it was usually way too late. Water is NOT A RECOMMENDED EXTINGUISHING MEDIA FOR ALCOHOL FIRES.
Might want to learn a bit more about alcohol and alcohol fires before opening your mouth. Read the MSDS for denatured alcohol.
Let me quote the relevant section for you:
EXTINGUISHING MEDIA:
Alcohol foam, CO2 or dry chemical.
FIREFIGHTING PROCEDURES:
Wear self-contained breathing apparatus approved by the U.S. Bureau of Mines. Use water to cool neighboring containers.[
SPECIAL FIRE AND EXPLOSION HAZARDS:
Flammable. Dangerous fire risk. Toxic by ingestion and inhalation. Vapors are heavier than air and will travel along ground to ignition source.
Finally, alcohol vapors are harder to detect than propane, which is spiked with mercaptan to make it very noticeable due to the odor of the mercaptan.
sailingdog is offline
