SailNet Community - View Single Post - Bilge pump preference
post #13 of Old 12-10-2008
nightowle
nightowle's Avatar
water line through hull
thanks for the input. Just to clarify, my sink through hull is just above the water line and is only sitting under water when the boat is heeled on a port tack. And yes, I meant to say I'd use a y valve and wasn't intending a pure 't'. Given that my boat has no automatic pump right now, I thought I'd go ahead and take advantage of the hole that is above the water line, and then remedy this properly when I next have the boat on the hard. I just haven't decided if I should add a through hull midship just below the toe rail, or extend a pipe all the way to the transom. The only existing holes at the transom are also just above the water line for the scuppers.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
nightowle is offline
