Bronze vs red brass
I'm doing some minor fuel re-plumbing in my engine compartment. I picked up a few quarter inch bronze fittings at WM, however they had no pipe nipples. After checking a few stores the best I could find is "red brass" 1/4 inch nipples. Should I use the two metals together? If you search the WM website for bronze nipples is give the response below. I'm using it in a dry location. I don't really have room to put rubber hose between each fitting. Should I just get red brass for the whole job despite less strength and corrosion resistance?
From the WM website...
We cannot source bronze nipples, and so we offer brass instead. Due to the difference in nobility between brass and bronze, we recommend that you not use them together in saltwater environments. We suggest the use of tailpieces and hose instead.
