SailNet Community - View Single Post - tiller pilot with wheel conversion??
post #5 of Old 12-11-2008
sailingdog
The problem is how much resistance does the wheel add to the tiller??? If it is a reasonable amount, like a cable steering system, then you can probably use a tiller pilot on a tiller connected to the tiller mount. If the system is fairly high resistance, like a worm gear or hydraulic system, it might not work as well.
sailingdog is offline
