Thread: "Plan C" Boat
  #30 (permalink)
Old 12-11-2008
mrwuffles's Avatar
mrwuffles mrwuffles is offline
mrwuffles is on a distinguished road
thats not the point to meat your plan c boat its to help a fellow member with finding a boat and he is definately qulified you shouldnt be coming in like you own the place telling people what to do
anyway I have a Catalina 22 and it has most of your requirements except the enclosed head, mstern idk if the swing keel on the 25 is the same as the 22 i assume it is, it isnt that hard to control actually a quite simple design except if you have to maintenance it looks like a pain to work on, I have mine set up with a roller furling so it is very simple to sail singlehanded, I can do it in almost any wiind we get easily. It also has a sliding galley with an alcohol stove which is nice and gets out of the way and turns into a bench when not in use, the one problem is if you have an older outboard that doesnt have an alternator you either have to get one that does or find other means of electricity we've been using a solar panel from west marine that worked perfectly to keep our battery topped off. On the head issue we had a porta potty so to enclose it just close the cabin and go outside =). Overall a good boat and easy to use and transport PM if you have any questions.
What's a signature?????
