Old 12-12-2008
SEMIJim's Avatar
SEMIJim SEMIJim is offline
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
FWIW: When I was actively involved in the weather station thing, right after I got mine, that was the "common wisdom": That if you wanted a decent weather station, Davis was the minimum you had to go. Problem is: Davis is relatively expensive--as compared to the cheap stuff that works only moderately well, if it works at all, and does not last.
Jim
s/v Abracadabra
1976 Pearson P30
