SailNet Community - View Single Post - Bildge Pumps
Thread: Bildge Pumps
post #3 of Old 12-12-2008
sailingdog
The best way to set bilge pumps up is to have a fairly small "maintenance" bilge pump with a small diameter hose that is mounted as low in the bilge as possible. The smaller the diameter hose, the less water that will flow back into the bilge. This will keep the bilge empty and take care of the basic drips that happen as a routine matter.
There should also be at least one larger bilge pump with its float switch mounted a couple inches above the level of the first bilge pump. This should be a very high volume bilge pump and is the one that will evacuate water in the case of a hole or downflooding.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
