SailNet Community - View Single Post - Ballasting
Thread: Ballasting
post #4 of Old 12-15-2008
Jeff_H
Moderator
Jeff_H's Avatar
I would doubt that 120 lbs in sandbags will make much of a difference in stability. 120 lbs of low density ballast placed near the centerline of a boat like the Hunter would not noticably increase stability. My sense is that the Hunter 25.5 was probably designed to use a working jib in over 12 knots of and that you may be using too large a headsail for the conditions.
Jeff_H is offline
