SailNet Community - View Single Post - Ballasting
Thread: Ballasting
post #5 of Old 12-15-2008
sailboy21
sailboy21's Avatar
I think there might be more inertial stability in the motor versions. Not much, but a little. Maybe a little more due to the engine acting as ballast. Smaller boats are very sensitive to weight. Also, keep in mind 120lbs might be on the light side. You should also include the weight of the added glass work for the engine bed & tank. Probably a lot more fuel capacity that you have for your OB. I would venture to say the two versions could very likely have slightly different sailing characteristics.
sailboy21 is offline
