mast mounted radar
I've pretty much decided, until I change mt mind again, to mount my 2kw radome on the mast of my crealock 31. If I mount it at the spreaders it will just be over the deck light, seems like it may be too close and may interfere with the top of the staysail. This is 18' off the deck. If I mount it over the tang of the inner forestay then it will be 26' high on a 37' mast, seems too high.
Another option would be to mount it under the spreaders and away from the top of the inner forestay but this would block the deck light.
Does anyone wish they had mounted the dome in a different location on the mast?
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
