  #18 (permalink)
Old 12-18-2008
pedcab's Avatar
pedcab pedcab is offline
pedcab is on a distinguished road
Originally Posted by waltsn View Post
One minor thing Id point out is that you may want to disconnect the circuit from the battery when the outboard is not in use since it would for example keep a three stage solar charge regulator from topping off the batteries as the charging voltage likely could not exceed 14 volts unless you had a big panel (the circuit shunts up to 50 watts or so to ground when 14 volts is exceeded).
You´re right.
That´s why I have my electrical instalation arranged in such a way that, whenever I´m no t on board, neither the regulator nor none of the electrical appliances on board are connected to the battery leaving only my small solar panel directly connected, in order to keep the cells topped up.
In addition to this, my electrical switch arrangement only lets me charge the batteries whenever the electricl panel is switched off the grid (by means of an SPDT switch), to prevent any current spikes from the alternator to damage my auto-pilot, bidata, etc...
Like this
regards
Pedro
Portugal
