SailNet Community - View Single Post - greetings from las vegas
post #6 of Old 12-18-2008 Thread Starter
Benny26
first off, to determine the amount of clowns in a mac 26 you would need to figure a few things...
is the cabin top up or down? we can assume its down as it would be under sail... (as though a boat load of clowns COULD manage to get under sail)
depending on the size of thier shoes, you could probably fit quite a few, more if you use midgets...
you have to use at least one dwarf, since thats all anyone could fit in the head... too many would be bad though, since the little guys are almost solid muscle, and usually sink.
you could probably find a couple really lanky ones to squeeze into the ballast tank, but nobody would think to empty it first...
vegas is great right now, ive never seen this much snow here before...
as for the water level, its always going down. depending on when you were here last, the cement factory on boulder island is waaaay out of the water now, and las vegas boat harbor has moved over next to lake mead marina at hemmingway harbor... where it used to be is now pretty dry...
dont let the bath ring around the lake fool you though, there is still plenty of area out there, i have so far only been in 2 of the 4 basins...
Benny26 is offline
