SailNet Community - View Single Post - Ballasting
Thread: Ballasting
post #9 of Old 12-19-2008
Sailormann
Here .. Pull this
The degree to which it will affect the boat is largely dependent upon the boat's displacement. What is the designed displacement of the boat ? What is the ballast to displacement ratio ? Under 30% Over 40% ??? If you have a boat that weighs 10,000 pounds, of which 3 or 4000 pounds is ballast 150 pounds is going to make a difference but not a significant one.
The added weight means it will take the boat longer to pick up speed but it also means it will take the boat longer to slow down. Inertia being what it is ...
Good Luck
Sailormann is offline
