SailNet Community - View Single Post - in search of easy roller furling (Schaefer Snapfurl?)
Old 05-18-2001
h20nut h20nut is offline
h20nut is on a distinguished road
Rbh1515,
Before sailnet was sailnet it was JSI. I worked in the hardware department for a number of years and sold Schaeffer,Harken,CDI,Profurl,and Hood furlers.
In most cases the application determined which furler was best for the job.
I attended the Harken tech school in Pewaukee and have tremendous respect for their company and products. Schaeffer is nearly bulletproof with excellent factory support. Same with Profurl. CDI is a great unit, in my opinion, for smaller boats up to about 33'' headstay. The Harken systems are top of the line and can be assembled over the headstay(removed from the boat) and then reinstalled by sending a man aloft and reattching the headstay complete with furler.
Harken''s unit00 did have production problems at first. They tried coextruding PVC and braided stainless but the different coefficients of expansion of the two mat''ls just didn''t work. To Harkens credit they would not release this unit until all the glitches were worked out. CDI''s Flexible furler spawned the Harken unit,Schaeffers Snapfurl,and Hoods Sea flex. These flex units were introduced primarily for trailer sailors so as not to damage rigid foils when transporting their boats. In a nutshell, if you trailer your boat the flex units are the way to go if not you''ll probably get the best performance from a rigid foil system. Hope this helps.
Good luck.
Waternut...............
