SailNet Community - View Single Post - Sealing my shrouds
post #8 of Old 12-24-2008
sailingdog
Don't use silicone... Silicone caulk really has no place on a boat. What you should probably do is make the gap around the plates a bit smaller by filling the excess gap with thickened epoxy. The gap shouldn't be 1/2" all-around. Bringing it down to 1/4" would be a good idea. If the chainplates flex more than that, you've got other problems to worry about. While you're at it, checking to make sure the deck is sound in the area, especially if the chain plate passes through a cored section of the deck, would be a really good idea. If the core is exposed, sealing it with thickened epoxy would also be a really good idea.
Making a stainless steel cover for the slot is a good idea. Make it out of the same grade stainless steel as the chainplates if you can.
Use SikaFlex 291, 3M 4200, or butyl tape to bed the stainless steel cover and seal the hole.
sailingdog is offline
