SailNet Community - View Single Post - adhering teak to fiberglass
post #10 of Old 12-24-2008
justified
Saildog has the right ideas on the cedar or the white oak strips 1/2" should be the right thickness, will still bend nicely to the shape of the hull. If you glue/epoxy the teak you will need to clean the teak with acetone or lacquer thinner to get rid of the natural oils in the wood then the epoxy will work fine. the other way would be to screw the finish on but you would want to use an over sized or elongated hole so that you allow for any movement/ flex in the hull, use a finish grommet washer with your screw.
Peter
justified is offline
