Yanmar 2QM15 Problem
A cold engine will emit carbon.The grey smoke is the ether (starting fluid) combustion products. Best to figure why you need starting fluid. Bad fuel, dirty or worn injectors or pump, or worn rings and valves are all culprits. I would approach it with attention in the respective order.
Best of Luck
