SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #24 of Old 12-30-2008
motovationcycles
Not just a member
Low Buck
This is my Nav Station. It used to be a shelf with everything hanging or sitting on the shelf. It cost me less then $100 to make it a lot nicer. It is easily removeable to gain access to the buss bars I installed behind it. I made it by first making patterns (the underside of the deck here has multiple camber). I scrounged around for enough 1/2" marine plywood. I then applied black formica (from Lowe's). By reusing the existing Mahagony fiddle rail i was able to make matching trim for the corner. The panel does not extend the entire lenght of the shelf I left a 12" space on the aft end. In this area I installed 2- 12volt outlets ,for a charging station. As well as mounting for my Wham mic charging/storage cradle. My Garmin 545 is able to be used at the nav station or in the seperate cradle in the cockpit. Both locations for the GPS are fully interfaced - NMEA for the VHF,autopilot. Audio out for the XM radio to the stereo. The GPS uses the internal antenna on deck and the remote antenna down below. Sorry for the lousy cellphone pics!
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
motovationcycles is offline
