Old 06-22-2004
haffiman37 haffiman37 is offline
haffiman37 is on a distinguished road
White Smoke from Older Diesel at Higher RPMs
White smoke on small Volvos are usually a sign of the cooling system beginning to clog up. This usually starts in the exhaust bend.Water gets in, but not enough out to prevent it from vapourizing in the hot exhaust hose. If your engine is raw-water cooled:dismantle the bend, clean and check and run a cleaner in the whole system. Take out the draicocks at the bottom of each cylinder and flush it from there with fresh water.If you have a two-circuit system, cleaning the heatexchanger and exhaust bend is normally enough.DO NOT put waterpressure at your raw water pump as this may dislocate the seals and fill your engine with water!
Sponsored Ad
