SailNet Community - View Single Post - Displacement or plane hull?
post #6 of Old 12-30-2008 Thread Starter
The displacement is just a first-order swag based on some similar light-weight designs. The original sketches where around 19000 displacement when I stumbled across an article about the Didi 38 which apparently uses something close to a semi-displacement hull. It supposedly achieved some pretty decent speed. Personally, I am really not all that interested in getting beat up by my boat or have to continually chase the helm, so I'll probably go back to a regular round bottom. I just wanted to explore all my options.
I would love to find some good books on practical design. But the local book stores don't stock any boating books beyond some picture albums. I found several interesting books on Amazon which I'll order in the near future.
I'm not worried about the software. Hydrostatics is rather straight-forward. I verified it using known hull shapes to check to see that the results matched. I'll continue to crosscheck it along the way. Hydrodynamics on the other hand is a little tougher.
Yes, I know I'm a newb to this at this stage, but I don't go into something like this without a lot of research before becoming committed. It's all on paper at this stage. FYI: You want pucker factor? Try test flying something you built.
Question: Is beam normally measured at the waterline? 99% of the definitions I've read state that beam is measured at the widest part of the boat's structure. The waterline beam measure makes much more engineering sense. Which is correct?
InetRoadkill is offline
