SailNet Community - View Single Post - Displacement or plane hull?
post #10 of Old 12-31-2008
sailingdog
The problem I see is that the boat isn't really wide enough to take advantage of a planing design, which generally requires a wide flat hull form, at least aft... and at 13,500 lbs., the boat is going to be relatively light in terms of displacement. Unless the boat is made of fairly lightweight, high-tech composites, IMHO, the boat is going to be relatively tender too, but that really depends on the exact hull form, keel design, ballast percentage, etc.... so without more information, you can't really say how it will perform.
The Dudley Dix designs are fairly decent ones from all I've seen... and if he's at 19,000 for his 38' design, I think that a 37' design that is only 13,500 is pretty light.
Good luck, have fun, and keep us posted.
sailingdog is offline
