Old 01-03-2009
lancelot9898 lancelot9898 is offline
lancelot9898 is on a distinguished road
Thanks for all the replies. The comment about insulated backstays and putting the hanks on the antenna part of the backstay is doable, but like you say it's difficult with the insulators being located so high. I think mine is about 10 feet off the deck. Also I'm not sure if transmitting on the SSB will be that effective with a riding sail attached. I would probably use the end of the boom and the topping lift to set it with out hanks. Not as effective as hanking on the backstay however.
The last comment concerning hurricane force winds is well taken since everything possible should be removed from the decks. The shock loads from swinging from one tack to another however is extreme and anything to keep the boat from swinging would be benificial IMHO. Numerous things can be tried and I've tied one being the second anchor hung on short scope from the bow to limit swing. Another is to use a second line tied to the anchor rode and lead back to the stern so that the boat lays at an angle to the wind. Not sure about this one since the least amount of windage presented is best. The same thing can be achieved using a riding sail lead to the rail. Under extreme conditions the dynamic loads would possibly be just as large if not larger due to surging to beam-to rather than from port to starboard. I think an argument can be made however that lying on one tack the force is more constant vs. a time when the rode may go slack when riding with bow directly into the wind and the resultant sudden surge on the opposite tack.
