SailNet Community - View Single Post - Pearson 30 motor questions
  #26 (permalink)
Old 01-07-2009
CalebD's Avatar
CalebD CalebD is offline
Tartan 27' owner
CalebD will become famous soon enough
I am starting to come round to Rockter's way of thinking that shutting off the fuel valve and burning up all the fuel in the line above the carb. is the way to go. My A4 is from 1967 and still kicking over nicely.
Personistic,
Glad to hear you got a rebuilt A4. There was a good chance that you could have got that old block kicking again but so be it. I assume that Moyer took your old engine?
Anyway, I know you spent some large boat bucks on the A4 replacement but now that you have done so you might consider putting in a heat exchanger and let your engine cool with fresh water/antifreeze - this will protect the engine block cooling passages from saltwater degradation and your engine will last longer (as if they can't last a long time with good maintenance anyway). Moyer Marine Online Store
Yes, your raw water strainer can get clogged by a plastic bag if the engine is running/sucking and it can get partially clogged by marine growth. Check on this when the water is warm enough to do so.
The Moyer A4 manual suggests that you install a 'T' valve fitting on the raw water intake so that you can run the engine on fresh water when on the hard or at the dock if you so desire. I think you should consider this as it is cheaper then the fresh water cooling system @ $700. My boat came with this adaptation and there is a garden hose input fitting on deck outside the cockpit coaming that will allow fresh water to be cycled through the cooling system. The only caveat here is that you should not put any FW hose into your engine at full blast as the pressure will likely backfeed into the cylidars and you will have new, bigger problems to worry about. I always use a 5 gal bucket and allow the water pump to suck the water out. I use some hot water hose and surgical hose to connect the garden hose fitting to the 5 gal bucket. Sometimes I have to prime the hose with liquid but once it is set it works like a charm.
It would likely have cost you twice the amount you spent for a new diesel engine replacement. Now you have basically a 'tractor' engine that is about as simple as they come and it is pretty easy to learn all about them. A new diesel would have been a different devil to get to know. Some of the parts of each are common but others are very different (gas vs diesel).
If you are not already a member over at the Moyer community forums I suggest you join tomorrow.
